Y'a même la version 1.11 avec les modifications suivantes
rePhase, a loudspeaker phase linearization, EQ and filtering tool
Changelog:
1.1.1 2016-10-29
New features:
- added a 64 bit IEEE-754 output format to accommodate BruteFIR:
http://tinyurl.com/htqvln8 Bug corrections:
- fader focus bug solved:
http://tinyurl.com/ztbp7cl - beefed-up clipboard handling to avoid bugs when loading measurements
by dragging them over the interface:
http://tinyurl.com/jygt7jx - removed the final optimization step that was recently added in
version 1.1.0 as it had some ill side effects in specific scenarios
Adjustments:
- renamed measurement "compensate" function to "invert" to avoid
confusions:
http://tinyurl.com/j76wm5w - reworked focus and entries editing in paragraphic EQ tabs:
* using the tab key now goes from one entry to the other as
expected, making it faster to edit multiple EQ points in a row
* clicking on an entry does select the entire content for ease of
editing
* middle click or double left click on the dB/° entry used to reset
the value to 0. This is now gone, but the same result can still
be achieved with a middle click on the fader
- internal DPI scaling adjustments
1.1.0 2016-10-27
New features:
- screenshot functionalities added to the file menu :
* "Save Graph Screenshot As..." saves current graph view with a
logo added to the bottom right corner
* "Save Window Screenshot As..." saves current window view with the
directory entry hidden for anonymity concerns
* supported bitmap file formats are PNG, GIF and JPEG
* graph screenshot also supports EPS vector file format
- 64 bits output formats handling (mono/stereo IEEE wav, txt)
- All-Pass filters added to the Minimum-Phase Filters tab
- measurement compensate mode to manually replicate a given measurement
(eg replicating a mic calibration file and getting its missing
minimum-phase response, replicating a target curve, etc.)
- added a "Clear Result" entry in the File menu, clearing result curves
and status
- reworked "what's new" changelog window to make it easier to read
Removed features:
- removed "complex" windowing algorithm which was deprecated since
version 0.9.0
An alert box will popup when loading settings using it
Bug corrections:
- bug correction for 2nd order minimum-phase filters with Q<0.5
An alert box will popup when loading settings containing that bug
* bug report:
http://tinyurl.com/z59qw4t - filename encoding bugfix: accents and other special characters
handling in setting, impulse, and measurement filenames and paths
(was supposed to be resolved since 0.9.7, but was not...)
- last updated graph setting sometimes remained unchanged after
resetting or loading new settings
- fixed a few instabilities:
* Horbach-Keele filters with R=1
* clipboard corner case errors
* NaN detection bugs
- fixed various graphical bugs:
* generation status remaining after reset
* misbehaved result phase curve when hide=-Inf
* view slots flickering in large view mode
Adjustments:
- faster constant Q, proportional Q and constant shape EQs calculation:
should be around three times as fast now, and should be notable when
manipulating EQ faders as well as during the first generation step
when a lot of EQ points are used
- added "Pano Phase Shuffler" presets in the Paragraphic Phase EQ tab
* source:
http://tinyurl.com/pano-shuffler * settings:
http://tinyurl.com/pano-shuffler-preset status text under the generation button
- added a final optimization step in moderate/extensive/maximal modes
with a correction factor set to 1
- added ± 15dB and ± 18dB ranges for convenience in paragraphic EQ tab
- increased EQ dB precision from 0.1dB to 0.01dB for manual editing
- set default optimization floor to -100dB
- faster startup time
