Code : Tout sélectionner
static uint8_t buffer[(SSD1305_LCDHEIGHT * SSD1305_LCDWIDTH / 8)] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xC0, 0xF0, 0xF8, 0xFC, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xF0, 0x00, 0x00, 0x00,
0x0C, 0x3E, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFC, 0xFC, 0xF8, 0xF0,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x9F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xDF, 0xE0, 0xE0, 0xE0,
0xE0, 0xE0, 0xE0, 0xE0, 0xC0, 0xC0, 0xC0, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0x0F, 0x1F, 0x1F, 0xBF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFD, 0xFD,
0xFB, 0x7B, 0xBF, 0xFF, 0xFF, 0xFC, 0x7F, 0xFF, 0xF7, 0xF7, 0xF7, 0xF7, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x3F, 0x3F, 0x1F, 0x0F, 0x0F, 0x07, 0x03, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xE0, 0xE0, 0xE0,
0x00, 0xC0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0xE0, 0xE0, 0xE0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xF8, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFD,
#if (SSD1305_LCDHEIGHT == 64)
0xFE, 0xFF, 0xFF, 0x3F, 0xFF, 0xFF, 0xFF, 0xFC, 0xF3, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFD, 0xF1,
0xC1, 0x01, 0x00, 0x00, 0x70, 0x78, 0x7C, 0x7C, 0x3C, 0x3C, 0x3C, 0x3C, 0x3C, 0xFC, 0xFC, 0xF8,
0xF0, 0x00, 0x00, 0xF0, 0xF8, 0xFC, 0xFC, 0x3C, 0x3C, 0x3C, 0x3C, 0x78, 0xFF, 0xFF, 0xFF, 0xFF,
0x00, 0x00, 0x70, 0x78, 0x7C, 0x7C, 0x3C, 0x3C, 0x3C, 0x3C, 0x3C, 0xFC, 0xFC, 0xF8, 0xF0, 0x00,
0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x3D, 0x3D, 0x3D, 0x00, 0x00, 0xFC, 0xFC, 0xFC, 0xFC, 0x70, 0x38,
0x3C, 0x3C, 0x3C, 0x00, 0xFC, 0xFC, 0xFC, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFC, 0xFC, 0xFC,
0xFC, 0x00, 0x00, 0xFC, 0xFC, 0xFC, 0xFC, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x3C, 0x3C, 0x3C,
0x00, 0x00, 0x00, 0x00, 0x1E, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x0F, 0x0F, 0x0F, 0x07, 0x07, 0x03,
0x03, 0x01, 0x00, 0x00, 0x00, 0x03, 0x07, 0x0F, 0x1F, 0x3F, 0x3F, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF,
0xFF, 0x00, 0x00, 0x00, 0xFC, 0xFE, 0xFF, 0xFF, 0xE7, 0xE7, 0xE7, 0xE7, 0xF7, 0xFF, 0xFF, 0xFF,
0xFF, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xE0, 0xE0, 0xE0, 0xE0, 0xF0, 0xFF, 0xFF, 0xFF, 0xFF,
0x00, 0x00, 0xFC, 0xFE, 0xFF, 0xFF, 0xE7, 0xE7, 0xE7, 0xE7, 0xF7, 0xFF, 0xFF, 0xFF, 0xFF, 0x00,
0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0xFF, 0xFF, 0xE0, 0xE0, 0xE0, 0xE0, 0xF0, 0xFF, 0xFF, 0xFF,
0xFF, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xE0, 0xE0, 0xE0,
0x00, 0x00, 0x00, 0x00, 0xF8, 0xF9, 0xF9, 0xF9, 0xF9, 0xF9, 0xF9, 0xF9, 0xF8, 0xF9, 0xF9, 0xF9,
0xF9, 0xF8, 0xF8, 0xF8, 0xF9, 0xF9, 0xF9, 0xF9, 0xF9, 0xF9, 0xF9, 0xF8, 0xF9, 0xF9, 0xF9, 0xF9,
0xF8, 0xF8, 0xF8, 0xF9, 0xF9, 0xF9, 0xF9, 0xF9, 0xF9, 0xF9, 0xF8, 0xF9, 0xF9, 0xF9, 0xF9, 0xF8,
0xF8, 0xF9, 0x09, 0xF9, 0x09, 0xD8, 0xB8, 0x78, 0x08, 0xF8, 0x09, 0xE9, 0xE9, 0x19, 0xF8, 0x08,
0xF8, 0xF8, 0x08, 0xF8, 0xD8, 0xA8, 0xA9, 0x69, 0xF9, 0xE9, 0x09, 0xE9, 0xF8, 0x09, 0xA9, 0x29,
0xD9, 0xF8, 0x08, 0xF9, 0x09, 0xA9, 0xA9, 0xF8, 0xD8, 0xA8, 0xA9, 0x69, 0xF9, 0xF9, 0xF9, 0xF9,
0x00, 0x00, 0x00, 0x00, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
0x01, 0x01, 0x00, 0x01, 0x00, 0x01, 0x01, 0x01, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01, 0x01, 0x01,
0x00, 0x00, 0x01, 0x01, 0x00, 0x00, 0x00, 0x01, 0x01, 0x01, 0x00, 0x01, 0x01, 0x00, 0x01, 0x01,
0x00, 0x01, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01, 0x01, 0x01, 0x01, 0x01
#endif
Le premier soucis, c'est qu'il contient une ligne de trop pour la partie 32 et une ligne en moins pour la partie 64. J'ai donc une erreur de compilation quand je teste avec la librairie telle quelle. J'ai donc tenté de supprimer une lignes, mais bien sur ça ne marche pas beaucoup mieux. En fait je ne comprend pas pourquoi le tableau est initialisé avec ces valeurs
Je vais essayer de reprendre ça plus calmement demain
